cel code 9
Old Sep 17, 2019 | 06:30 AM
efdave's Avatar
Default cel code 9
hello everyone,
1989 hatchback si 1.6l
all stock
new distributor within the year kept the old one as a back up,havent had problems at all until yesterday
the other morning I was driving to work and got the CEL.
counted the blinks and i have the CEL code#9
pulled the 10amp hazard fuse before leaving work yesterday to clear but it came back on.
this morning driving to work came on again but while going up the highway it seemed to hiccup twice.
not really bad, kind of quick but was noticeable
any ideas ?
should I take the dizzy back and get another one?
thanks
-dave
Old Sep 17, 2019 | 07:12 AM
scelestus's Avatar
Default Re: cel code 9
If your old one was still working properly, I would try swapping that to see if you get the same behavior just in case something's worn out in the wiring or a ground is corroding. You're probably right that it is the distributor though.
Old Sep 17, 2019 | 08:29 AM
efdave's Avatar
do you think the dizzy possibly being defective, it would cause that little hiccup tho while I was in acceleration?
Old Sep 17, 2019 | 10:18 AM
scelestus's Avatar
Yes. The Cyl. 1 sensor is used for ignition timing, so your hiccup is probably a miss due to an injector triggering a little early or late.
Old Sep 17, 2019 | 12:57 PM
efdave's Avatar
ok cool, ill replace and then update the situation . I appreciate it
Old Sep 20, 2019 | 09:10 AM
efdave's Avatar
UPDATE:
The distributor was bad put a new one in yesterday. No cel code yet was able to turn mine in for a defective exchange and all is well thanks for all the help
-dave
oneprblmcat
Jul 11, 2012 07:30 PM
92civeg
Apr 5, 2010 07:07 AM
slacks
Sep 11, 2007 04:19 PM
snatch
Dec 17, 2004 11:13 AM
