Bosch 2200cc injectors with top hats and pig tails $400 idled for 10 mins to big for my setup my lose your gain
Fresh never ran never fired all new B18A1 AEBS sleeved block 83x89 Crowler billet I beams Aries outlaw high boost pistons HD pins rings acl race bearings cometic 83mm hg $3200 short block
Also have B series ram horn T4 w/38 mm wg flange with s366sx3 with hood exit dump tube and 3” up pipe have a tail 38mm gate to go with has 8psi spring turbo has only idle time once. $900 obo will get pics soon
parts im looking for is s300 or neptune rtp p28 ecu with bbg
Sorry guys never get on here anymore life’s been crazy. I do have other short blocks and long blocks for sell as well. Give me a txt and we can talk. 530-513-8561 thanks for looking. Also have a lot of misc. b series parts. Will make great deals and even better package deals. Lmk stuff got to go.
83x89 b18a1 sleeved block all freash never fired.Aries outlaw hd piston wrist pin and ring package, crower billet rods, polish and balanced ls crank acl race bearings. This short block is good well up to 1300hp As you can tell the bores show this is all freashly done.
Stock gsr short block rebuilt with 0 miles. with built head. Skunk 2 valves, blox springs and retainer, blox p2 cams and gears. Head has 1500miles in it. 1850obo
Can’t believe no one needs a built short block for a way lower cost then starting from scratch. Or injectors or a turbo or a rebuilt gsr with a built head for 500 more then importanting a used one from japan
