piston ring gap problem
Old Jul 22, 2019 | 06:52 AM
Brembomaster's Avatar
Default piston ring gap problem
Hello, I have bought two set of ring , but those are have the ring gap problem, a little bit larger than OEM spec.
Ring gap:
top ring : 0.19- 0.20
2nd ring: 0.20-0.21
I know somebody run with little bit loose for their engine, My car just for track, May I run with this ring gap?? If not, May I buy a set of oversize ring and file it?
Thanks
Old Jul 22, 2019 | 10:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: piston ring gap problem
If you are going to track this vehicle... run those gaps. You should be just fine.
Old Jul 22, 2019 | 11:20 PM
If run with this gap , will it make lot of crank pressure or compression leakage?
my set up with high compression piston and run with N/A
Old Jul 23, 2019 | 03:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Not likely... maybe a slight increase in oil consumption... but you reduce the chances of the ring gap closing up to zero and damaging the engine from getting the parts too hot.
Old Jul 23, 2019 | 08:34 PM
Thanks.
You know me i am say in inches , not mm??
0.19 inches and 0.21 inches
Thanks for your help, i do not have any experience about ring gap clearance.
Old Jul 23, 2019 | 10:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Originally Posted by Brembomaster
Thanks.
Sorry OP, I thought you meant .019" for the top ring and .021" for the second ring. If you meant that you have measured .19mm and .21mm, these values are NOT loose at all !!! That would be very tight and require filing.
Old Jul 23, 2019 | 10:28 PM
YESYES,, It's is 0.019' for the top and 0.021' for second. ( convert to mm is 0.48mm for top and 0.51mm for second ring)
Old Jul 26, 2019 | 02:22 PM
Chance EG's Avatar
What you have is fine.
Brembomaster
Jul 13, 2019 03:58 PM
pornstar4777
10
Jan 10, 2008 04:16 AM
Muckman
Nov 11, 2005 02:48 PM
boostmywankle
Jan 27, 2005 07:23 PM
