arias ring gap
Old Jan 27, 2005 | 12:06 PM
boostmywankle's Avatar
Default arias ring gap
hey i have a set of 9:1 .020 over...i need to find a ring gap to you. ive head many but not sure what to go one. Earl gave me .018 TOP and .020 BOTTOM. just checkin to see what ppl are running and any sujestions?
Old Jan 27, 2005 | 04:23 PM
Default Re: arias ring gap (96teggyls)
anyone confirm this???
Old Jan 27, 2005 | 04:41 PM
RA166E's Avatar
Thats what I would run with a nitrous or boosted engine.
Old Jan 27, 2005 | 06:28 PM
Default Re: arias ring gap (RA166E)
ok thanks, anyone else??
Old Jan 27, 2005 | 07:01 PM
earl's Avatar
old skool thinking used to say .018" upper and .013" middle but now most builders set the second ring gap a few thou looser than the upper. Came out of Nascar research on what happens to pressure passing the top ring. You want it to continue down the piston and not turn around and unseat the upper ring.
I still think the rule of thumb of .006" of gap per inch of bore for the upper ring works great.
Some people still think the second ring has to do with compression control but it is actually for additional oil control. If it is installed up side down, it will actually push oil into your combustion chamber rather than keep it out of where it should not be.
Old Jan 27, 2005 | 07:08 PM
Default Re: arias ring gap (earl)
ok...thanks earl! im going to set my rings to your specs up for such a good guy! got my crank back fast also!
Old Jan 27, 2005 | 07:23 PM
unsungsohc's Avatar
When we talked to arias they gave us .016 up top and .020 bottom so that sounds good
blackeg
Engine Machining & Assembly
Jun 18, 2015 08:03 AM
b20vtech
Apr 29, 2007 06:45 AM
d16dcoe45
Oct 25, 2006 06:23 PM
Muckman
Nov 11, 2005 02:48 PM
b00stedbyFastrax
Nov 18, 2002 01:07 PM
