Wire External Tach - 95 Sedan DX - Help requested
Old Jul 21, 2019 | 02:17 PM
Tyler DM's Avatar
Default Wire External Tach - 95 Sedan DX - Help requested
I’m trying to wire in my tach and I’m sure y’all get this a lot or it gets asked a lot but I’ve watch some videos of YouTube got some advice from here but nothing seems to be working I have power to the tach good ground just no actual tach signal I hooked it up to the little pill looking thing under the hood on driver side where I have seen it said a lot or done a lot but it’s not working any help would be great thanks!!!
Old Jul 21, 2019 | 06:49 PM
muellersfan's Avatar
Default re: Wire External Tach - 95 Sedan DX - Help requested
Civc year and trim?
Old Jul 21, 2019 | 06:50 PM
Tyler DM's Avatar
Originally Posted by muellersfan
Civc year and trim?
95 and I believe it’s the dx it’s the 4 door sedan
Old Jul 22, 2019 | 02:19 AM
cp_auto12's Avatar
How many wires coming off the back? Did you go wire color to color because I know sometimes the same color wire does something different for am parts, Double check your tach wire diagram and match it up with correct wire from the ecu
Old Jul 22, 2019 | 02:28 AM
Tyler DM's Avatar
How do I know which wire to connect to from the ecu? And off the tach I got it has
red-power to tach
white-power to tach light
black-ground
Green-signal to tach
when I have the car running the needle on the tach I installed goes to zero with car off it’s below zero so I’ve read that means I got good power just not getting tach signal
Old Jul 22, 2019 | 03:49 AM
Tachometer signal comes from the blue wire attached to the igniter unit inside the distributor.
Old Jul 22, 2019 | 03:54 AM
Tyler DM's Avatar
Okay there’s no other place I can grab it from? Like I said I’ve seen people get it from the little pill on the drivers side up near the clutch reservoir it’s has one blue wire attached to it and that’s where I’ve got it connected but doesn’t read anything.
Old Jul 22, 2019 | 04:37 PM
Default Re: Wire External Tach - 95 Sedan DX - Help requested
Pull out the multimeter.
Does the blue wire in the tach test connector and the igniter unit have continuity with the cluster tachometer pin?
If so, the igniter unit may be bad.
Does the blue wire attached to the igniter unit have continuity with body ground?
If so, the blue wire is shorted to ground.
Old Jul 22, 2019 | 04:39 PM
Tyler DM's Avatar
Does the blue wire attached to the igniter unit continuity with body ground?
If so the blue wire is shorted to ground.
Okay I’ll test all that tomorrow thanks for all the help I’ll be in touch if that does or doesn’t solve the problem..
Old Jul 22, 2019 | 09:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Is the tach new ??? How do you prepare it for a 4-cylinder signal operation ??? Are there wire loops that need to be cut or dip switches that need to be set/properly connected ??? What do the installation instructions say ??? Connecting a test wire from the green wire directly to the blue wire at the distributor on the two-wire plug will diagnose the possibility that the test tach lead that you are trying to use may not be connected.
Old Jul 23, 2019 | 02:18 AM
NVturbo's Avatar
O.G. triple O.G.
OP, it would have been cheaper to get a used gauge cluster (from a LX or EX model) instead of a hideous aftermarket tach.
Old Jul 23, 2019 | 11:42 AM
Tyler DM's Avatar
I’m getting rid of the cluster it’s not a daily I’m build a mini stock 4 cylinder class car and wanted the rpm and oil pressure gauge and violent temp gauge but can’t get the tach to work and the one on the original cluster doesn’t either
Old Jul 23, 2019 | 11:44 AM
Tyler DM's Avatar
Okay so I should connect it to the 2 wire plug at the distributor it has a blue and a black with yellow stripe wires?? Connect it to the blue?and yes it is brand new
Old Jul 23, 2019 | 11:45 AM
Tyler DM's Avatar
Also if the tach test lead isn’t connected where should it be connected?
Old Jul 23, 2019 | 01:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Without a TON of explanation... it should ultimately connect to the blue wire in the 2-wire plug at the distributor. If you have removed the factory instrument cluster OR removed some wiring under the dash, you may have severed the connection between the blue tach wire at the distributor and the blue/silver test lead over near the driver's side shock tower.
Old Jul 23, 2019 | 02:44 PM
Tyler DM's Avatar
Okay I’ll try that and see what happened and yes the entire car is gutted but no wire that I know have has been removed but thanks for all the help like I said I’ll try the 2 wire plug and see what happens
Old Jul 23, 2019 | 03:37 PM
Tyler DM's Avatar
Okay so I’ve tried the blue wire on the two wire plug on the distributor and still nothing think it could be a faulty tach even though it’s 3 days old
Old Jul 23, 2019 | 07:06 PM
These^^ are the tests that will solve the problem. Everything else I'm hearing in this thread is just guessing rather than unbiased diagnostic tests, which is the thinking man's approach to solving problems.
Pull out the multimeter and get to work if you want to understand how logical and methodical progress is made.
Old Aug 8, 2019 | 08:47 AM
Tyler DM's Avatar
If the igniter unit is bad would the car not run though? Or run like crap? That’s just me wondering and think that if something inside the distributor is bad you know? Still a problem that I can’t figure out to get the tach to work
JDM Hunter
Feb 14, 2009 09:42 AM
vtecftw
Jun 22, 2007 04:12 PM
teddy_dc2
Mar 15, 2007 07:02 PM
fu*kfaceC1EH2
Jul 9, 2003 09:48 PM
batboy18
Sep 4, 2001 12:41 PM
