99 Civic no middle vent flow
Old Jul 20, 2019 | 11:36 AM
Tommy Runoffski's Avatar
Default 99 Civic no middle vent flow
No airflow through middle two dash vents. Old posts say ducting or unplugged harness.
This ac only gets middling cool. Only at the start and end of a drive, also.
So, I've got two things, at least going on.
Can I get to the ducting?
Where do I look for wiring harness?
Or is this a control door simply gunked up or worn out?
Pete
Old Jul 21, 2019 | 10:17 AM
stin1's Avatar
Loved
Community Favorite
Default Re: 99 Civic no middle vent flow
My guess is your mode motor has failed and is stuck in the defrost mode. Feel near the glass and see if it is blowing air on the defrost vents.
Old Jul 21, 2019 | 10:22 AM
stin1's Avatar
Loved
Community Favorite
They are also designed in the event of failure to fail in defrost mode for safety reasons.
Old Jul 21, 2019 | 10:56 AM
I think you're right. Found the little black plastic motor box. Going to order one.
Then, I've got to figure out why the AC gets ice cold, then warm, then fades out to stay warm until the end of about a 20 minute drive, when it comes back to lukewarm type cool.
If it was always semi cool if think it needs charged but it moves all over the place. Compressor seems consistent so....
Old Jul 21, 2019 | 04:39 PM
stin1's Avatar
Loved
Community Favorite
Wait until you see how it behaves after you replace the mode motor . It's in defrost and the ac is going to act different. Then move forward if need be. Wear gloves when replacing,that grove is sharp!
h22paul
Nov 19, 2010 03:57 PM
grangey
Jun 25, 2010 09:18 AM
IntegraTypeR
May 10, 2007 01:28 AM
rminor205
Apr 22, 2007 08:50 AM
olsonateam
May 20, 2004 01:08 PM
