Gear/ belt compatability issue.
Old Jul 14, 2019 | 06:23 PM
Robert0064's Avatar
Default Gear/ belt compatability issue.
Hey wsp guy , I need some help. I have a Honda Civic 2000 I had a put a f20b with h22 head in but I’m stuck on timing. My belt fits on the cam gears the water pump just doesn’t fit on my crankshaft drive gear that’s from a h23a. I need help ASAP is it the belt or the gear ? PLEASE SOMBODY LET ME
KNOW WHAT IT IS . In desperate need right now . Thanks
Old Jul 14, 2019 | 10:12 PM
Aradin's Avatar
Premium Member
Default re: Gear/ belt compatability issue.
By H23A you mean the JDM Blue top model?
Pull the crank gear. If it's stamped P13 then it's the same thing the F20B/H22 uses. If it's not, that's the gear you need.
The timing belt can be a bit fidgety to get on under normal circumstances and it's easy to install it a tooth off.
Old Jul 15, 2019 | 06:30 AM
Robert0064's Avatar
No it’s the red top and I believe the one off the h23 says p13 but the belt that goes on the cam shaft don’t fit on the gear ? Could I get a different belt to fit both?
Old Jul 15, 2019 | 06:44 AM
Robert0064's Avatar
And no the gear I have is off a prelude a h23 non vtec engine black top but doesn’t look like the rest of the h series covers
Old Jul 15, 2019 | 01:09 PM
Aradin's Avatar
Premium Member
Assuming you bought the correct belt to begin with, no you should not be swapping belts around. You have something going on that's causing your issue and swapping different belts around is just going to cause more issues. The correct belt for an H22/F20B/JDM H23A is a Gates T226. There is no difference between the original F20B head and H22 head you swapped on as far as timing goes, so the belt remains the same. As I stated above, you need the crank gear off of an H22/F20B/JDM H23A. The USDM Non-VTEC H23 crank gear is different and they are not interchangeable.
Old Jul 16, 2019 | 07:31 AM
snobordboy's Avatar
Moderator
Here is your issue, the gear is not compatible with everything else you are using, you need the H22A/ H23A Vtec/ F20B gear.
And please use actual titles that illustrate your need, not "help please"
Old Jul 16, 2019 | 08:10 PM
Robert0064's Avatar
Default Re: Gear/ belt compatability issue.
Does anybody know where I can buy one at Becasue I’ve been looking and they all say discontinued ???
Old Jul 16, 2019 | 11:10 PM
Aradin's Avatar
Premium Member
eBay maybe. I probably have one I could part with for a price but I won't be at my shop for a few more days. Send me a PM if interested.
Old Jul 17, 2019 | 09:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I have a H22A crank timing gear... and I can use the H23A non-vtec crank timing gear that you have, so do you wanna trade ??? If so, send me a PM.
Old Jul 21, 2019 | 09:20 PM
Robert0064's Avatar
I will trade you text me at+12678194470
Old Jul 21, 2019 | 09:22 PM
Robert0064's Avatar
Send me a text at+12678194470
Old Apr 18, 2022 | 05:49 PM
camsol's Avatar
you still have one by chance
stackz
Jan 7, 2011 05:50 PM
McFlurry
Mar 21, 2008 05:31 PM
tmrtwo
May 13, 2007 05:42 PM
EGhatch22
Dec 28, 2004 06:45 AM
