Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 Crv Losing Power
Old Jul 8, 2019 | 08:39 AM
Knots914's Avatar
Default 2000 Crv Losing Power
Hey guys need some help my crv is slow on the get up was doing some research said it could be a faulty cap and rotor from my distributor or need a compression test any thing else it could be PLEASE HELP
Old Jul 8, 2019 | 10:17 AM
canister's Avatar
5 Year Member
Default Re: 2000 Crv Losing Power
How bad is it?
Any codes?
Did you check spark plugs?
Old Jul 8, 2019 | 11:34 AM
Knots914's Avatar
No codes changed spark plugs like 8 months ago
Old Jul 8, 2019 | 02:06 PM
canister's Avatar
5 Year Member
So how bad is it on the scale from 0 to 10 where 0 is runs like new and 10 is not moving at all?
Old Jul 8, 2019 | 03:13 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Slower than normal?
Old Jul 9, 2019 | 11:05 AM
Knots914's Avatar
Like a 7
Old Jul 10, 2019 | 06:38 AM
canister's Avatar
5 Year Member
Pull any codes you could read. Are you getting carbon buildup and knocking?
Run a can of Seafoam through a 1/4 tank and do a Seafoam spray cleaning process at the same time. Then change your oil. Are you on high mileage oil already? You should be if you are not. Valvoline Maxlife is not bad, but some swear by Mobil Formula1 and other high mileage products. This would help reduce or eliminate the oil getting into the combustion chambers through the valve seals, and other leaks.
Check for vacuum leaks. Check/replace spark plugs.
See if any calipers are dragging or e-brake stuck.
smercer
Feb 9, 2005 10:12 AM
crazyimport
Feb 5, 2005 03:33 PM
terribl3jon
Aug 21, 2004 01:19 PM
spoonef
Aug 6, 2003 03:28 PM
Digital-R
Aug 3, 2001 11:07 AM
