D15b bogging
I have an 88 civic sedan with a d15b and I just did a mpfi swap everything runs great but my problem is the car starts to bog and lose power when the tank is less than 3 quarters full. It still does it on a full tank but not nearly as much as when its less than 3 quarters full. I put in a new fuel pump , new fuel filter new fuel pump sock. When I figured out it was a fuel problem i rented the autozone fuel pressure tester and ran the car with it on. The car has 33 psi at idle. But while I'm driving and the bog occurs the pressure drops to around 10 - 15 psi. I restart the car and everything is fine till it starts to bog again. Any ideas or suggestions of what it might be ? Any help is appeciated
I did clean out the fuel tank when I dropped it. I could check the filter to see if it is dirty before redropping the tank. Is there a possibiility that the tank isnt getting. Vented properly ?
Thank you for the suggestions and I will get back with hopefully a problem solved. Trully appreciated
Did the old and new fuel pump sock look exactly the same? I have heard people have this issue when they replaced their old fuel pump sock. The stock one is longer and sits deeper in the tank and some of the supplied replacement socks are too short.
EFn-DirtySouth
19
Apr 5, 2014 04:24 PM
NO fuel pressure... car was running then lost all pressure, Aeromotive, dual walbro, stainless lines
HickamHatch
Sep 24, 2008 02:01 PM
MAYHEM
Mar 1, 2005 09:07 PM
