fuel filter or pump?
Old Jun 28, 2006 | 08:17 AM
Mariokdiddy's Avatar
Default fuel filter or pump?
My car is having a problem! when i step on the gas it feels like its not getting enough fuel or is my fuel pump acting up?
my fuel pressure regulator used to read something still when i turn the car off, but now it doesn't anymore! It takes me a little bit to start the car! And when its running its sound quiet like its about to cut off or something!
When the car is on it reads about 25 on the fuel pressure guage! its used to read higher!
Anyone please help!!!!!!
95 acura integra gsr
Old Jun 28, 2006 | 08:51 AM
jdm_bones's Avatar
Default Re: fuel filter or pump? (Mariokdiddy)
Do you smell any gas, it sounds almost like you might have a leak somewhere..I would start by checking all your fuel lines for leaks and replacing the fuel filter, because it's cheap...If it continues, I'd swap a buddies fuel pump and see if that does the trick if it does, buy a new fuel pump...If it continues look for possible fuel pressure regulator.
Old Jun 28, 2006 | 09:04 AM
i just recently added an msd blaster coil and was wondering if that or the timming has anything to do with it?
Old Jun 28, 2006 | 09:13 AM
qfast817's Avatar
Default Re: (Mariokdiddy)
well i would stay away from msd,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">I would start by checking all your fuel lines for leaks and replacing the fuel filter, because it's cheap...If it continues, I'd swap a buddies fuel pump and see if that does the trick if it does, buy a new fuel pump...If it continues look for possible fuel pressure regulator. </TD></TR></TABLE>
Old Jun 28, 2006 | 09:23 AM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mariokdiddy &raquo;</TD></TR><TR><TD CLASS="quote">i just recently added an msd blaster coil and was wondering if that or the timming has anything to do with it? </TD></TR></TABLE>
This was not mentioned before, but was it can also cause this...Get a timing gun and check timing as well...But yeah there is no need for msd unless you are booasting.
Old Jun 28, 2006 | 09:48 AM
FRAWSTY's Avatar
or on bottle^
Old Jun 28, 2006 | 09:59 AM
do you think it could be dirty or plugged injectors?
Old Jun 28, 2006 | 10:27 AM
jdm_bones's Avatar
Yeah it can, also be bad or dirty injectors...Check to see if you have broken injectors...This could effect injector spray pattern and can also cause, what you have mentioning... So check all the options before spending big money is what I am trying to say...Also you may what to check your Dizzy cap and rotor, they might be bad..
Old Jun 28, 2006 | 01:21 PM
problem is fixed thanx for the help!
Is was my fuel pump!
WheaMyRyceGo
May 31, 2009 04:37 PM
hondastudent1on1
Jul 5, 2008 02:54 PM
iNetForce
Nov 13, 2005 08:27 PM
Lei Siew Long
Jan 2, 2003 07:41 PM
