Troubleshooting: B16 oil leak after gasket replacement-cam gear side
Old Jul 7, 2019 | 05:45 PM
boostedblue23's Avatar
Default Troubleshooting: B16 oil leak after gasket replacement-cam gear side
So I just finished replacing head gasket and all the seals on my Cylinder head on my built turbo 2000 civic si. I noticed and oil leak where the head meets the block on timing belt side. I know there’s a common leak from these from the tranny corner side but this is opposite side. I looked up it could be my cam seals but those were replaced and brand new. I used a cometic head gasket (no copper spray) and torqued everything to spec ( headgasket isn’t upside down). I am not experiencing any other head gasket symptoms car runs great. I just noticed a slight leak in that corner after 30 mins of idling. Not sure where I should start.
Old Jul 10, 2019 | 12:52 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Troubleshooting: B16 oil leak after gasket replacement-cam gear side
It could be leaking from the valve cover gasket or the cam seals and running down to the head/block interface.
boostedblue23
15
Jul 10, 2019 05:00 AM
si_freak
Aug 22, 2009 07:41 PM
urtz
Dec 9, 2006 07:56 AM
Blanket Jackson
Sep 12, 2003 09:43 PM
redintheface
May 27, 2003 10:40 AM
