Integra B20 (high comp) swapped
Old Jul 7, 2019 | 05:24 PM
Jaydan Williams's Avatar
Default Integra B20 (high comp) swapped
Is there any way I can get ps & ac? Bought the car with swap and can't find anything on this subject for this specific swap. Just curious if it's possible, as well as what I'd need?
Old Jul 7, 2019 | 07:55 PM
MotorMouth93's Avatar
10 Year Member
Default Re: Integra B20 (high comp) swapped
The PS pump and AC compressor bolt up to a B20 the same as they do with a B18, the blocks are identical externally. The only difference would be in the belts if the B20 still has the B20 crank pulley, the B20 crank pulley is sized differently so you'll need different belts.
Old Jul 7, 2019 | 11:51 PM
jdmark1's Avatar
You have a b-series motor, the same motor that came in all Integras. So the way the AC and PS were hooked up from the factory is the same way you can hook yours up. Just install them the same way any Integra would have it stock.
Old Jul 8, 2019 | 08:17 PM
tony_2018's Avatar
Fish Twig
look 4 b18b p/s bracket and ac bracket.
Atheist
Sep 12, 2009 02:20 PM
Charlie Moua
Oct 1, 2002 08:39 PM
crxcess
Aug 24, 2002 02:38 PM
