Thoughts on the f22 block with h22 head
Old Jul 7, 2019 | 12:30 AM
Richmac585's Avatar
Default Thoughts on the f22 block with h22 head
So I'm looking to build a 92 lude with a h22 head and f22 block to be turbo I'm using it as a street and strip car for a ride around town and a fun weekend at the track any thoughts let me know pros and cons and how hard this is to do
Old Jul 7, 2019 | 03:32 AM
TimiK's Avatar
10 Year Member
Default Re: Thoughts on the f22 block with h22 head
Just sleeve h22
Old Jul 7, 2019 | 07:38 AM
Richmac585's Avatar
The car comes with the f22 block in it so I would have to sleeve and swap
Old Jul 7, 2019 | 12:27 PM
Aradin's Avatar
Premium Member
"G" builds are prone to problems.
Old Jul 10, 2019 | 11:06 AM
Tachi's Avatar
I'm going to ask, why do you need the twin cam head? Unless you're trying to go for high horsepower I think the standard non vtec head would be fine.
@ Aradin what problems are those?
Old Jul 10, 2019 | 11:58 AM
Chance EG's Avatar
This subject has been beaten to death over the years. The oil and water passages do not line up correctly, it's not even close to being designed to work together. It's guaranteed to fail unless you dump a bunch of time and special machining/tooling into the equation which then makes it VASTLY inferior to just a straight H22 swap or even a K swap.
Absolutely do not attempt this.
Old Jul 10, 2019 | 12:30 PM
Aradin's Avatar
Premium Member
^ Beat me to it. It's really not worth the trouble. It's nothing like doing an LS/VTEC or similar like so many people want to compare it to. It adds a lot of points for things to break, leak, etc etc. They don't even make power comparable to a bone stock H. A straight H/F20B swap is just better because it works. If iron sleeves are a requirement and you want a DOHC platform, F20Bs are ~$500 from any importer - sometimes cheaper depending on the time of year.
Old Jul 13, 2019 | 12:11 AM
Richmac585's Avatar
Ok so since swapping the head is a no what all would I need to swap from the f22 to the h22
Old Jul 13, 2019 | 12:03 PM
Aradin's Avatar
Premium Member
To use the search function and/or google. Very common swap that's been done for decades now. There's info everywhere.
Old Jul 13, 2019 | 12:51 PM
CD8's Avatar
CD8
Boost the single cam first, plenty of fun around town and weekends. Then when you blow it up, swap the motor.
g22kiddos
Dec 4, 2008 05:13 AM
dcskater6767
May 10, 2007 10:47 AM
94civicgreen
Feb 9, 2006 07:18 AM
Y2A
Nov 23, 2003 09:05 PM
