Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Speed Sensor Questions
Old Jul 6, 2019 | 11:46 AM
Hondaindy209's Avatar
Default Speed Sensor Questions
Hey there, I just replaced the clutch in my 2015 Accord EX 6-speed. It drives and shifts smoothly so everything is usable, but a few things are not working properly after I put everything back together.
First, my speedometer is not working. During the process of taking out my hubs I took out the speed sensors that stick into the hub. I made sure to put them back in and I didn’t stress the wires that were connected to the sensor at any time. It seems simple enough but is there something I needed to do to properly reinsert them or should I just buy new sensors...?
Second, when I was driving prior to the clutch change, if I drove fast enough, my shifter wouldn’t allow me to move into reverse. Now, I can be on the freeway going 65 and I can put it in position to pull it into reverse which freaks me out because it would be really easy to accidentally shift into reverse instead of 6th. Did I loosen something I need to tighten when I changed my clutch or can someone tell me if this is a product of the speed sensor not working as well?
Any information is appreciated
Old Jul 17, 2019 | 07:48 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Speed Sensor Questions
Both the speedometer and reverse lock out solenoid utilize the signal from the output shaft sensor to function. Either its not plugged in correctly(or at all) or its broken.
I believe this sensor is on the front of the transmission,by the radiator.
But I dont remeber for sure,Google is your friend here.
Kris05TSX
Transmission & Drivetrain
11
Jun 25, 2024 10:04 PM
jonnyshatter
Jul 4, 2013 11:02 PM
BeantownBeatdow
Feb 2, 2011 02:26 PM
norcalcrx
Jul 16, 2003 07:01 AM
Looose_R
Mar 27, 2002 04:49 PM
