what ecu? help
Old May 30, 2019 | 10:40 PM
lonely_driver4's Avatar
Default what ecu? help
i have a 97 civic coupe with a b16a swap. what stock ecu can i use to have it run and drive. i need to pass NYS inspection with no check engine light. i plan on having one ecu for passing inspection and a obd1 ecu that is chipped for after inspection.
Old May 30, 2019 | 10:51 PM
Default Re: what ecu? help
is the usdm p30 the only option? i have a b16a2 block and tranny with a b16a head.
Old May 31, 2019 | 12:56 AM
tony_2018's Avatar
Fish Twig
p2t?
Old May 31, 2019 | 06:15 AM
Originally Posted by tony_2018
p2t?
has to be obd2a isnt the p2t the 99-00 civic si? obd2b
Old May 31, 2019 | 07:28 AM
Chrispy42's Avatar
P2T with a conversion harness, P30, or P72. Will need to do the CKF bypass trick and have a working second O2 sensor.
https://honda-tech.com/forums/hybrid...A-%2A-1972711/
Old May 31, 2019 | 05:19 PM
thank you !!!
Old May 31, 2019 | 05:38 PM
tony_2018's Avatar
Fish Twig
why does it have to be obd2a?
Old May 31, 2019 | 06:35 PM
I thought it had to be obd2a because it's a 97 and when they plug in for inspection it needs to match. if I can use obd2b would I just need a jumper?
Old May 31, 2019 | 08:34 PM
tony_2018's Avatar
Fish Twig
YES
Old Jun 1, 2019 | 06:18 AM
YES
are you sure I can pass inspection with an obd2b on an obd2a car not trying to question your knowledge but I'm about to buy an ecu
Old Jun 1, 2019 | 01:03 PM
tony_2018's Avatar
Fish Twig
You haven't given me any documents stating whats needed in your 'county', I don't even know where you live. /thread
Old Jun 1, 2019 | 02:52 PM
I live in NYS I'll find the requirements for inspection and drop the link
Old Jun 1, 2019 | 02:55 PM
https://dmv.ny.gov/brochure/new-york...ection-program
ef yu
Jan 16, 2012 08:53 AM
daeaudio
15
Sep 17, 2005 11:21 AM
pwrdbyDOHC
Jan 18, 2005 12:26 PM
civiclxb16a
Dec 16, 2004 03:10 PM
Dpatton
Oct 16, 2003 10:47 PM
