B20vtec Starts and Immediately Dies
Old May 18, 2019 | 07:02 AM
rplatt's Avatar
Default B20vtec Starts and Immediately Dies
Hello all! Hoping to get some help with my b20vtec in my CRX. As you can see from the title it starts strong but then immediately dies. I will try to attach a video. Compression is 220-220-225-240, I have fuel, spark, and it is in time. Tested the resistance on the CYP, CKP, and TDC sensors and all are within spec. Grounds to thermostat, transmission, and valve cover are good. I pulled the d15 in January and it was running fine so I wouldn't think that they problem would be with the ignition switch or main relay (fuel pump primes too). I should also mention that the spark plugs were wet with fuel when I checked them; I'm guessing its because the motor dies so quickly but could be something. Just curious about what I should try next. Here are my specs: B20z2 with a GSR head, Skunk2 intake manifold and throttle body, Hondata intake manifold gasket, DSM 440 injectors, Skunk2 Pro Stage 3 cams with Skunk2 valve train (valves, springs, retainers, LMA's), Golden Eagle head gasket, 84.5mm pistons (I calculated 12.3:1 compression ratio), chipped p28 with a basemap programmed for my parts (yes, I know I will still need to get a tune). I had previously converted the car to MPFI and it ran great. Again, looking for some things to try next; any help is appreciated!
Edit: Don't know why I couldn't upload the video but here is a youtube link: https://www.youtube.com/watch?v=11Oi...ature=youtu.be
Old May 19, 2019 | 04:28 AM
tony_2018's Avatar
Fish Twig
Default Re: B20vtec Starts and Immediately Dies
That didn't sound like a strong start...
Old May 20, 2019 | 05:55 AM
AllMtrRex's Avatar
Did you degree the cams? Pro 3 cams with what 84.5mm pistons?
Old May 20, 2019 | 05:27 PM
rplatt's Avatar
Thanks for the reply. Yes, 84.5mm pistons and I did degree the cams. I don't think I got it perfect as it was my first time degreeing cams. I felt like I could get it close and take care of the rest during tuning but I'm starting to wonder if that was false thinking. What do you think?
Old May 21, 2019 | 04:18 AM
AllMtrRex's Avatar
What kind of separation did you end up with Intake/Exhaust?
Old May 23, 2019 | 05:56 AM
rplatt's Avatar
-2 on the intake side, +1 exhaust
TheProffessa
24
Nov 17, 2011 01:11 PM
z_life
Jun 30, 2007 09:33 AM
egCoupe
Aug 15, 2005 05:55 PM
VTECRaZeR
Jun 19, 2004 06:51 AM
