D16z6
Old May 14, 2019 | 08:14 PM
edgarzubia's Avatar
Default D16z6
Hello I have a turbo d16z6 with cp pistons, eagle rods, arp head studs, dsm t25 turbo, dsm 450 injectors, stock head with new stem seals, h22 throttle body. I got my car tuned to pass emissions and run great. Recently I decided to take my cat off and put a test pipe. After a while I put the cat back on because I was seeing a lot of gray and black smoke. Even with the car being warm it stills smokes. I have replaced the head gasket and still had the same issue. I did a compression test and everything came out good with good compression. I also did a leak down test and everything came out good as well. We went and took the motor apart saw that one of the rings looked a little damaged so we honed the cylinder wall and put a new ring on. I changed the head gasket one more time, and even checked the turbo to see if it’s the problem. I have ran out of ideas on what it can be. Now it’s more like a gray color smoke and it kind of smells like corn in a way. I also put new stem seals. Can it be something with the tune, or maybe the fact that I went from a cat to a test pipe?? Any ideas??
Old May 14, 2019 | 09:55 PM
Honderachinaldo's Avatar
Default Re: D16z6
PVC?
Old May 14, 2019 | 09:58 PM
Default Re: D16z6
Remove the hose going from pvc to plenum and see if there's oil up in there
Old May 15, 2019 | 05:25 AM
edgarzubia's Avatar
Default Re: D16z6
New pvc valve, but I’ll double check to see if there’s not oil build up
Old May 15, 2019 | 06:22 PM
Default Re: D16z6
My y8/b7 sucks oil through into mani on startup despite pvc and hose replacement. Even cleaned breather box on back of block out. I finally just capped it all off because who cares, D. Still a perplexing problem
Old May 16, 2019 | 12:06 AM
OEDRO's Avatar
Default Re: D16z6
Welcome to the forum.
Old May 18, 2019 | 11:28 AM
edgarzubia's Avatar
Default Re: D16z6
Found my issue it was the head. I am pissing oil from the head going into the headers.
Nisif
Nov 9, 2016 10:46 AM
SolScifen
18
Jan 7, 2012 04:49 PM
widecrx
Jul 21, 2007 02:58 PM
MniMeHatch89
10
Feb 1, 2006 10:24 AM
Snail Tuning
Nov 23, 2004 02:37 PM
