B16 motor swapped into a 99 civic Ex OBD2 wires and connector removal
Old May 5, 2019 | 06:25 AM
Ken D.'s Avatar
Default B16 motor swapped into a 99 civic Ex OBD2 wires and connector removal
Hi everyone, So Ive been thinking about taking out a B16 engine and transmission from a 2000 Honda Civic Si into a 99 Honda Civic EX. (both Automatic Trans)
I'm swapping everything over from the 00 Civic Si to the 99 civic EX
My question is about the The OBD2 connector located under the driverside kick panel.
Is the OBD2 connector and wires included in the engine wiring harness of the motor and engine computer (ECU)
I just want to know if I have to pull the dash apart to remove it. or is the OBD2 wires tied into the wiring harness from under the dash where all the fuses are located?
thank you very much guys for any input.
Old May 5, 2019 | 07:50 AM
tony_2018's Avatar
Fish Twig
Default Re: B16 motor swapped into a 99 civic Ex OBD2 wires and connector removal
Take the engine harness and dash harness too. Makes doing a 5spd swap more complete
Old May 5, 2019 | 09:12 AM
Ken D.'s Avatar
Do I have to remove the dash to remove the dash wiring harness?
Old May 5, 2019 | 01:48 PM
tony_2018's Avatar
Fish Twig
its common
Old May 5, 2019 | 05:39 PM
Ken D.'s Avatar
So this dash harness is not tied into the fuse block under the steering column!
thanks very much for the insight and advice!
Old May 5, 2019 | 06:55 PM
tony_2018's Avatar
Fish Twig
My bad, the firewall harness. Its behind the dash but its not called the dash harness
Old May 6, 2019 | 07:59 AM
Ken D.'s Avatar
So I do need to remove the Dash?
Is there anything else I need to take apart and swap over to the EX civic?
Old May 6, 2019 | 06:24 PM
tony_2018's Avatar
Fish Twig
Yeah, CMC, clutch pedal, clutch lines
Old May 7, 2019 | 09:14 AM
Ken D.'s Avatar
Its an automatic transmission.
Old May 7, 2019 | 10:53 AM
tony_2018's Avatar
Fish Twig
So you're telling me this honda civic si has an automatic b16?
hondacurious
Apr 21, 2014 06:15 AM
maritime_ef
Oct 26, 2011 09:05 PM
97dssi
Jul 28, 2011 11:33 AM
Redrover
Audio / Security / Video
16
Feb 17, 2011 02:12 PM
