Rewiring the dash
Old Feb 12, 2011 | 12:55 PM
Redrover's Avatar
Default Rewiring the dash
Got a deal on a 99 civic coupe, the whole harness is fried 6 inches back into the dash from where the deck should be. Want to rewire it and have a friend who knows wiring who's gonna help, question is, was told the wires can be traced back to a harness that just comes out and I can rerun them. Gonna check fuses too, just haven't had the opportunity. Will Honda have the harness or Do I need to find it used? Or is it easier to just go back, clip the wires where they are fried and extend them?
Old Feb 12, 2011 | 08:25 PM
fcm's Avatar
fcm
Old Fart
Default Re: Rewiring the dash
Once wiring has burnt back into the harness itself it is best, in the long run, to replace the complete harness.
Looks like your less then 100mi from the Portland area, there are 3 PicknPulls up there, [down there for me] you can probablyfind a harness at one of them. 94
Old Feb 12, 2011 | 09:36 PM
Redrover's Avatar
That's the new plan, found a diagram off of one of the posts. The hunt is on.
Old Feb 13, 2011 | 07:37 AM
fcm's Avatar
fcm
Old Fart
There are two (2) 99 Civics at PicknPull one at Portland south and one at Portland north you can also check at PicknPull for a "cross referance", other year/model Civic/Honda/Acura that use the same dash harness. 94
Old Feb 13, 2011 | 09:46 AM
Redrover's Avatar
And maybe help me with what this plug is? I need a good manual for wiring, I've heard helms for mechanical, does it also have wiring diagrams? I worked this stuff in the military, but as far as cars go, my only experience is on an SRT, this is my first foray into the honda world. Learning day by day.
Thanks for your help.
Old Feb 13, 2011 | 03:29 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
That is the security plug for the oem alarm. Your better off pulling the whole dash out to make sure nonething else is melted or damage and replace the whole harness.
Old Feb 13, 2011 | 06:14 PM
fcm's Avatar
fcm
Old Fart
If you replace the harness it will be "plugnplay", you do not need a manual, although even a Haynes is good to have.
The only way to be sure you repaired all the damaged wiring, is to pull the dash and "open" the harness, I would only do all that work if I could not find an intact/undamaged one from a bone yard, [at a good price]. 94
Old Feb 14, 2011 | 11:23 AM
Redrover's Avatar
Sounds like... a good time. lol Appreciate the help. What is a good price? Brackets don't sound encouraging.
Old Feb 14, 2011 | 12:23 PM
fcm's Avatar
fcm
Old Fart
A complete harness at PicknPull will cost you $13.49,up here.
What do you mean, " Brackets don't sound encouraging".
It should not take you more then 2-3 hr max to pull the dash out of the car, it takes me 1hr at most to pull a 99 Civic dash, it's not that hard, replacing dash harness another .5hr
Probably a little longer then 3-4 hr for you to reinstall the dash, about 1.5 hr for me.
Make it a weekend project andyou should be good to go by Sun, afternoon. 94
Old Feb 14, 2011 | 12:38 PM
Redrover's Avatar
You put a good price in brackets, thought it was sarcasm as to it being expensive. Gonna find some time later this week, there's a couple of wreckers in town that might have something as well. Thanks for the info, I'll be giving it a go.
Old Feb 14, 2011 | 08:02 PM
Redrover's Avatar
G n R auto wreckers quoted me 99 for the harness.
Old Feb 15, 2011 | 05:37 AM
fcm's Avatar
fcm
Old Fart
Do they remove it or is it a pull it yourself kind of yard?
If they pull the parts, your paying labour for them to do it. 94
Old Feb 16, 2011 | 07:22 PM
Redrover's Avatar
Where does the green plug connect to? I just saw a walk through that said it plugged into the cluster? I also have no dash lights... Car is an electrical nightmare.
So far:
Rewire melted harness-Get a new harness
No dash lights-Figure it out once I pull the dash
Right blinker stays lit when headlights are on-Check grounds and bulb connections
So far, that's all I've really taken tally of. Dome light and reverse lights work fine.
Old Feb 17, 2011 | 05:34 AM
fcm's Avatar
fcm
Old Fart
As mentioned, The green plug is for the OEM alarm, if no OEM alarm it does not plug into anything. 94
Old Feb 17, 2011 | 11:26 AM
Redrover's Avatar
One last question, does it matter if it's out of an automatic or manual? I didn't assume so but wanted to ask just in case
Old Feb 17, 2011 | 12:07 PM
fcm's Avatar
fcm
Old Fart
Yes it will matter, although you could make either work with some rewiring, but that would defeat the point of putting in an undamaged one.94
Old Feb 17, 2011 | 02:12 PM
Redrover's Avatar
Alright. Glad I asked
civic-steve-94
10
May 24, 2011 09:20 PM
ParistsCP
May 7, 2006 07:16 AM
Phat_Jax
Apr 22, 2005 12:45 PM
