Having idle issues
Old May 2, 2019 | 06:09 PM
pimpgixxer04's Avatar
Default Having idle issues
Hey guys so i just bought this 2000 civic ex 1.6l d16y8. Anyway day i took delivery the waterpump took a dump so i replaced the entire cooling system short of the heater core, replaced the water pump and timing belt. Now im having idle issues. It was super low (300 range) so i bumped it up using the idle mixture screw. Oh and i bled the crap out of the cooling system. So now when i come up to a light or a stop it idles at 1200 drops to 1000 for a second then to 800 then back up to 1200 and stays for a bit, anybody have any ideas? I havent cleaned my iacv yet but plan to. Anything else it could be?
Old May 3, 2019 | 04:07 AM
mk378's Avatar
Default Re: Having idle issues
Besides the coolant (which you should check one more time, when it is cold, open the radiator and confirm it is full to the top), the IACV can get dirty (remove and clean) or the ECT can give flakey readings to the ECU (test with OBDII live data or test sensor with ohmmeter).
On an EX manual, unplug the IACV and set the air screw for 420 rpm, i.e. barely running. This is only for two wire IACVs, it does not apply to EX auto which has a 3 wire IACV.
Old May 3, 2019 | 09:57 AM
Ok ill check the coolant again, maybe try and bleed it some more, as for the iacv, its a two wire, ill clean it, and whats this ECT you speak of. How do i test it with my ohm meter?
mattcod6fan
Dec 13, 2015 06:23 AM
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
willfly
Dec 28, 2013 02:01 PM
send4mike
May 2, 2012 05:24 AM
mkrieger500
Mar 2, 2011 12:53 PM
