Ect sensor wiring ... and other isues
Old May 1, 2019 | 03:47 AM
Acc3l3ratoR's Avatar
Icon5 Ect sensor wiring ... and other isues
Is it ok to wire a ECT sensor directly to the ecu ??
Is it necesary to rund the signal ground wire through the junction connector or can i run it directly to the signal wire going in the ecu?
I had some trouble with a mous who chwed som od the wire harness and now the ect sensor signal oscilates up and down ... ist is never steady.
Seen it with a datalogger ... conedcted to the 3 pin service connnector (hondash interface).
Old May 1, 2019 | 07:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Ect sensor wiring ... and other isues
Repair the wires that are damaged... don't try to run the wires a different way.
lakahang
Apr 9, 2012 07:14 PM
spoolnbyu
Jun 5, 2005 07:46 PM
AdamITR
Apr 26, 2003 01:28 PM
