De-Pin Obd1 Distributor 2 Wire connector?
Jewelers flat tip screw drivers (plural) will be required.
One to lift the holding tab and one to lift the female spade connector a little when you pull back on the wire.
Quite often ppl will shove the small screwdriver from the back to lift the holding tab. I personally attack it from the front.
0.7mm flathead precision screwdriver will depin any Honda plug. And go from the front, the clip holding the connector should be between the two arches, hope that makes sense. Also, there are a few threads out there that walk you through how to depin different connectors.
How to: Depin various types of Honda plugs - Carolina Hondas
Thanks guys! I was able to get it through the center, with a filed down took that I made from wiper blade metal.... I pushed up the clip, slid the wire right out.
Mine broke, old and brittle, And I tried prying towards inside, flat part of terminals, did not comprehend, I think the locks snapped when I DID go between the arches
Plug looks like the female side of fan plug, if I EVER see one in junkyard.
tigueremalo
Oct 27, 2007 07:11 PM
jdmaddiction
Apr 19, 2006 02:44 AM
xtreme-customz
Oct 30, 2005 07:08 AM
91CivicHatchback
May 22, 2005 03:45 PM
