92-95 civic del sol si motor swap
Old Apr 22, 2019 | 12:06 PM
Austin18's Avatar
Default 92-95 civic del sol si motor swap
Just wanting to know what’s the best swap for a del sol and the easiest one to do
Old Apr 22, 2019 | 12:14 PM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
Default Re: 92-95 civic del sol si motor swap
Which Del Sol model? Base? S? Si? or VTEC?
Any D or B series will fit with proper mounts. Depending on your model type, minimal to zero wiring will be required.
Easiest and cheapest would be a D swap...don't need anything other than the motor. Assuming you are going from a D15B7 to a D16Z6 (SOHC VTEC) all you will need to do is wire in VTEC.
B swaps are just as easy, but will require different engine mounts.
Old Apr 22, 2019 | 12:16 PM
Austin18's Avatar
It is a si and it has a d16y8 in it already which is nice and has a decent amount of power for how little the car is just wanting to do more I’ve been told to do an h swap but haven’t really messed with and h series motors
Old Apr 22, 2019 | 12:23 PM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
H22's are good. Some modifications will be necessary such as using the cable shift linkage, mounts extend some wires, etc. Most eliminate the AC and PS, but, its not 100% an issue. I'd also recommend a change in your suspension setup as the H series are heavier than a B or a D series.
Old Apr 23, 2019 | 10:22 AM
Freedo_Civegra's Avatar
J35
Old Apr 24, 2019 | 08:10 AM
NVturbo's Avatar
O.G. triple O.G.
rebuild the motor and boost it. Hence my sig.....
lusciouslett12
Mar 17, 2015 12:32 PM
mish__
Mar 18, 2011 05:13 PM
ludedood97
Jan 18, 2005 08:47 PM
nautica_t
Jun 25, 2004 08:08 PM
phantom_sol
Sep 30, 2003 08:57 AM
