92-95 civic del sol si motor swap
Re: 92-95 civic del sol si motor swap
Which Del Sol model? Base? S? Si? or VTEC?
Any D or B series will fit with proper mounts. Depending on your model type, minimal to zero wiring will be required.
Easiest and cheapest would be a D swap...don't need anything other than the motor. Assuming you are going from a D15B7 to a D16Z6 (SOHC VTEC) all you will need to do is wire in VTEC.
B swaps are just as easy, but will require different engine mounts.
It is a si and it has a d16y8 in it already which is nice and has a decent amount of power for how little the car is just wanting to do more I’ve been told to do an h swap but haven’t really messed with and h series motors
H22's are good. Some modifications will be necessary such as using the cable shift linkage, mounts extend some wires, etc. Most eliminate the AC and PS, but, its not 100% an issue. I'd also recommend a change in your suspension setup as the H series are heavier than a B or a D series.
O.G. triple O.G.
rebuild the motor and boost it. Hence my sig.....
mish__
03-18-2011 05:13 PM
ludedood97
01-18-2005 08:47 PM
phantom_sol
09-30-2003 08:57 AM
