Mini me to B series swap
Old Apr 16, 2019 | 08:42 PM
Krauthammer's Avatar
Default Mini me to B series swap
Alright, I read the swap sticky forum. From what I understood, B18's are plug and play in my 94 DX originally with a D15B7, now has a Mini-me, so I have the VTEC wiring and the Hondata ECU. Can anyone help me figure out what all is needed exactly to complete the swap?
Old Apr 17, 2019 | 06:30 AM
civichxtreme2's Avatar
Default Re: Mini me to B series swap
Which B18?
Old Apr 17, 2019 | 08:55 AM
Honestly whichever B series is the easiest to put in
Old Apr 17, 2019 | 09:29 AM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
Honestly, they are all about the same short of wiring.
With a VTEC unit (B16A/B, B18C/R) you will need to wire in a VTEC solenoid and sensor. Also I don't remember if the VX had a 1-wire o2 or that odd 5-wire o2 or if it has a normal 4 wire, if it is anything by a 4 wire, you will need to deal with it. With a B18A/B, it is straight plug and play (if your current car has VTEC, then you will have two plugs on the harness that will have no where to plug at). If you want a B20, is much like the B18A/B, but you will want to change the intake manifold or the hood may not close due to the tall intake runners on that manifold.
In terms of mounting, you will need B series drivers side mount, rear bracket, and transmission torque mount.
If you want to run the D-series A/C compressor you will need the A/C bracket from a P54 del sol.
B series axles and half-shaft will be required.
Old Apr 17, 2019 | 04:22 PM
Awesome! Looks like I'll need axles, mounts, intake and exhaust. I've already converted to VTEC and 4 wire O2. Thanks for all the info
Alexpbnj
Jul 25, 2010 10:07 AM
Turbomadness07
Apr 13, 2004 05:41 PM
phantom_sol
Feb 1, 2004 09:11 PM
y_do_u_want_gio
Jan 4, 2003 07:32 AM
