Car cuts off without warning while driving
Old Apr 16, 2019 | 07:35 PM
Siabraham1990's Avatar
Default Car cuts off without warning while driving
Need help. Car cuts off while driving and/or coming to a stop without warning it’s like the car thinks I’m turning the key off so maybe the switch is the problem? It’s a 1995 civic with an ls swap. Can’t seem to figure out the problem. It doesn’t have any check engine lights.
Old Apr 16, 2019 | 07:52 PM
tony_2018's Avatar
Fish Twig
Default Re: Car cuts off without warning while driving
main relay? ignition switch? igniter?
Old Apr 16, 2019 | 08:08 PM
changed the main relay, same problem. Even got a whole new distributor and still same problem . The ignition switch is next in list.
Old Apr 16, 2019 | 10:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You have described symptoms that are typical of an ignition switch/pigtail failure.
Old Apr 17, 2019 | 04:37 AM
mk378's Avatar
When it stalls out, don't touch the key until you check if the battery and oil warning lights come on. Normally they will come on whenever the key is on but the engine is not turning. If they are out but come back on when you jiggle the key, it's a bad ignition switch.
A lot more cost-effective to test first before replacing.
badfish2282
May 15, 2009 08:45 PM
GO-FIGHT-KILL
May 22, 2007 06:34 PM
b00sted4dr
Jul 31, 2006 05:00 PM
Xxcivic99xX
Jul 2, 2005 03:01 AM
