CAR WONT SHIFT OUT OF 2ND GEAR
Old 04-15-2019, 12:25 PM
Default CAR WONT SHIFT OUT OF 2ND GEAR
hello i have a 2000 honda civic ex i have changed transmission fluid and when i drive it it will shift from 1st to 2nd gear but it will not shift out of 2nd gear it stays in 2nd gear what could my problem be?
crystalsky is offline
Old 04-15-2019, 02:21 PM
Default Re: CAR WONT SHIFT OUT OF 2ND GEAR
How did you confirm you have enough fluid after replacing?
Smoove910 is offline
Old 04-15-2019, 07:32 PM
cause i had put the 3 required quarts into the car and i have extra i also let it heat up and checked the fluid the fluid level is full not over full just full
Old 04-15-2019, 07:59 PM
K20.ek's Avatar
Guessing itís a automatic tranny... cause manual doesnít have a dipstick to check fluid at least not on my old civic hatch
K20.ek is offline
Old 04-15-2019, 08:13 PM
yes its an automatic tranny could i have a bad solenoid?
Old 04-15-2019, 08:29 PM
K20.ek's Avatar
What kind of tranny fluid you used?
Yes, it could be one of the solenoids went bad.
K20.ek is offline
Old 04-15-2019, 08:37 PM
i used the tranny fluid for hondas this is also my first time owning a car my car was given to me after i got my license it just randomly done this about a week ago i changed the fluid it was very dark but didnt smell burnt
Old 04-15-2019, 08:43 PM
K20.ek's Avatar
Did it do it before you changed the fluid?
either way, get those solenoids check to see which went bad.
K20.ek is offline
Old 04-15-2019, 08:56 PM
yeah it did and i researched and found out i need to change my fluid and did it didnt help it at all
Old 04-17-2019, 04:47 AM
You need to scan the computer. Not shifting out of second gear is a general fail-safe mode which the computer does when it detects any one of several problems.
mk378 is offline
  • Ask a Question
Question Title:
Description:
