GSRTeg02's 2000 integra GS-R's planned turbo project: Suggestions are welcome
Hey guys, I finally got another integra and I'm going to pick it up tonight! It's a 2000 integra gsr with no engine/trans. My goals are first and foremost to build it right and by the right people. My hp goals are 350-400hp. I want to be able to drive this to work 2 to 3 times a week. I drive 50miles to work. The engine will be a b18c1 and I'm not sure which trans to go with. I am not going to just throw this build together. I am one that if skunk2 has the best cams for the setup I want, then that's what I'm gonna buy. I'm asking for yalls advise on what my setup should be to make this a reliable boosted car. Thanks!
GSR transmission, CSS block, h-beam rods, forged pistons, Go-Autoworks SX500 kit, larger injectors and fuel pump, engine management of your choice, and a dyno session. Stock B18C1's can handle that power, but for reliability, I'd beef up the bottom end some, especially if planning to do this on pump gas.
I agree with DaX, go with CSS if wanting to build for longevity, especially on pump gas, but it can be done without CSS as well. My GSR stock sleeve has 11,000 miles on it making 400whp with E85. I also drive it 50 miles round trip 2-3 times a week or more, weather permitting.
I might not recommend this unless you are able to keep an eye on things and make occasional adjustments on the tune yourself as needed. If you want to be able to "set it and forget it" then build more conservatively.
Don't forget a nice stage 4 or 5 clutch, too.
Yeh, I am the service manager at a Nissan dealership, so I have alot of help with guys that are also diehard jdm fans. I would like to run pump gas, so whatever I have to do for the longevity, I will do.
I’m running gsr engine too except I have
ls crank
ls eagle rods
9.0.1 Carrillo pistons
ferrea valves
ctr cams/ adjustable bwks gears
gsr tranny/ ACT 6 puck clutch w/ clutchmasters flywheel
1000cc Bosch Style injectors/ AEM fpr
255lph walbro fuel pump w/ relay
skunk2 manni
s300v3 hondata
60-1 Garrett turbo stage 3 63hotside .70coldside
hallman boost controller
Next weekend Friday I will put on the Dyno and aiming for 350-400whp too.
ls crank
ls eagle rods
ferrea valves
skunk2 manni
s300v3 hondata
Yeah on e85 you can go 400whp on a 81.5 stock sleeve.
Maybe even higher if you measure ovalness and go 81.25mm
I'd personally advise OP to get a clutch with a heavier pressure pedal in lieu of an overly aggressive disc (for example, get a heavier pressure plate if that's an option instead of a 4 puck or 6 puck ceramic disk). In all likelihood some sort of combination between the two will be necessary, but the better you can plan that out the better the overall driveability of the car will be on the street.
