Em1 with jdm b16a throwing iac and knock sensor code
So i have have 99 em1 with a jdm b16a in it i have a chipped p28 (Hondata) in it car starts but i have to hold gas pedal for car to stay on if i let go of gas it stalls out but if i hold the gas pedal to car is warmed up it will still on and idle around 9k rpm i connect my Ecu to smanger to try and remove CEL but i can’t seem to disable the iac or knock sensor codes motor is mostly stock only have intake and headers, stock exhaust, any help would be appreciated
Put a working iacv on it, this will get it to idle correct. No sense in deleting this part, never understood why people do this (not the same as removing coolant lines). As for deleting the knock code, make sure your hondata is functioning correct, you should simply have to disable the knock sensor under whatever parameter it’s located and then upload the new setting. Post a screenshot maybe.
sloweh3
Feb 22, 2005 04:57 PM
birds_sol_94
Aug 19, 2004 04:23 PM
