04 Honda Pilot Replaced Timing Belt Possible bent valves?
I replaced the timing belt on my pilot made sure it was TDC tried to start it up and it acted like it wanted to start but just made this winding noise. Ive been doing research since the day the timing belt broke, which was a few months ago... Everything i have looked up or researched has all come to the same dumbfound answers, which is it could possibly be bent valves but not 100% sure.... Cant do a compression test if the vehicle wont start so please someone give me some real reliable help so I can get my truck back on the road!
You don't start the engine to do a compression test. If there is nothing but a straight whine when cranking, you likely bent valves. Check you mechanical running until you're absolutely positive it is correct.
bnuk013
Jul 19, 2006 08:36 AM
