Ep3 type r speedo needle
Old Mar 31, 2019 | 02:42 PM
Ddot123's Avatar
Default Ep3 type r speedo needle
Hi just wondering if anyone has come across this issue,when my car has been sat a few days and I turn the ignition on sometimes the Speedo needle shoots up and down and does the same when I start the car and I’m letting it warm up it still moves up and down also does it for a while when driving,it will correct itself to the speed I am doing say 30mph but still shoots up and down back to 0mph.once I have drove the car for a little while it stops doing it? Could this be a nackered vss sensor? Thanks!
Old Apr 1, 2019 | 06:05 AM
NDNV's Avatar
Default Re: Ep3 type r speedo needle
Any CEL with a code for the VSS?
Check the #10 (7.5 A) fuse in the Driver's Under-Dash fuse/Relay Box.
Check ground for the gauge assembly.
Troubleshoot the VSS circuit for short or open, faulty gauge assembly/connector or a faulty PCM.
CiViCShella
May 2, 2013 01:44 PM
ONEhaque
Nov 4, 2008 06:31 PM
EgDude
Jun 11, 2008 02:30 PM
_Bug_
13
Feb 22, 2006 07:30 AM
b18_racer805
14
Mar 26, 2005 07:00 PM
