Bad ECU? fuse #44
Old Mar 28, 2019 | 10:33 AM
Hutchinfun's Avatar
Icon5 Bad ECU? fuse #44
Hey guys, I have a 2000 civic ex 5speed with a y8 in it. Awhile ago i bought a p28 off of fb marketplace. I wasn't able to test it at the time because i had my engine taken apart.
When i did test it, it blew the #44 fuse FI E/M when i turned the key to on. This caused my fuel pump to not prime. Fuse #13 is fine.
The stock ecu doesn't cause this problem. I also have a p13 ecu laying around and that works just fine. So my obd1 jumper isn't the problem.
It has to be the Ecu. I've looked at the inside of it and all the caps and diode look fine. Is this ECU toast or is there anything i can do to get it working?
Thanks.
Old Mar 28, 2019 | 08:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Bad ECU? fuse #44
You should test before you buy... now go and find another P28. The one you have is cashed. Chalk this up to a teachable moment... a life lesson.
Old Mar 29, 2019 | 04:47 AM
mk378's Avatar
Check the big diodes near the plug end with a meter. They are there to protect from reverse voltage or over volts, and they can fail shorted when they've had enough of it.
Kid-jdm-teggy
17
Jan 28, 2015 08:57 PM
liquidrider
Feb 16, 2010 05:00 PM
hoursinexile
Nov 17, 2009 10:14 AM
onepoint-gsr
Feb 28, 2006 01:55 AM
