Assistance needed: D16Z6 ECU / Wiring Harness Diagram/ Pinout for classic Mini Cooper
Old Mar 23, 2019 | 12:43 PM
howell839's Avatar
Default Assistance needed: D16Z6 ECU / Wiring Harness Diagram/ Pinout for classic Mini Cooper
hi all I'm new here. iv just fitted a d16z6 into my classic mini i have a p28 ecu and i was wondering if anyone has a pin out for the ecu what each wire does and pin out for the 5 plugs in the engine compartment. any help is muchly appreciated
Old Mar 23, 2019 | 05:14 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default re: Assistance needed: D16Z6 ECU / Wiring Harness Diagram/ Pinout for classic Mini Cooper
Google "civic OBD1 ECU pinouts" and "civic shock tower pinouts"
Old Mar 24, 2019 | 10:29 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: Assistance needed: D16Z6 ECU / Wiring Harness Diagram/ Pinout for classic Mini Co
If you want to build essentially a stand alone engine harness the easiest way I've found is by running a 96-00 civic ex harness with a obd1 jumper harness. Basically it gets rid of the shock tower plugs besides one which is mostly ecu power, ground and the fat wire for the starter solenoid. I wired up my crx all motor drag car this way and it was very easy. I'll be doing the same harness setup on my insight when I single cam swap it. The ecu plugins go straight into the cabin and the green plug is for the cluster if I remember right.
veekster87
Aug 21, 2010 12:16 PM
DC5_Angelo
Nov 7, 2008 09:12 AM
what1118
Dec 15, 2007 07:00 PM
Inaniac
Aug 5, 2001 09:16 AM
