Options ? Trans mount bolt threads stripped
Old Mar 23, 2019 | 08:52 AM
K-G's Avatar
K-G
Default Options ? Trans mount bolt threads stripped
all 3 tranny motor mount holes are stripped. Also looks like someone previously tapped the one on the right and went too far down and thru.
Any ways there’s not even any thread left inside (so it looks like). The bolts slide in and out. I can get a few threads in two holes.
What would you guys reccomend doing ?
Old Mar 23, 2019 | 08:54 AM
K-G's Avatar
K-G
Default Re: Options ?
Correct me if I’m wrong but I believe the size is M12x1.25.(the one size my tap and die set does not contain)
Would it be worth running a m12x1.25 tap through the hole?
Or would I be wasting my time
Old Mar 23, 2019 | 10:02 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Try it first just so you can keep OEM, but likely wasting time. Plenty of material there to go bigger though. Like M14x1.25. But that hole into the trans, though. I guess you could tap it upside down so nothing falls in and gums up the gears.....
Old Mar 23, 2019 | 10:09 AM
K-G's Avatar
K-G
yeah that’s what I would like to do. I just found this out now. I’m passed. Worst part about it is trans is mounted to the motor. Thankfully amazon prime is nice. Tap will b here tomorrow.
So M14 x 1.25 would b the next size to go up to if I was to go bigger ?
Old Mar 23, 2019 | 10:11 AM
tony_2018's Avatar
Fish Twig
Default Re: Options ? Trans mount bolt threads stripped
helicoil, timserts?
Old Mar 23, 2019 | 10:13 AM
K-G's Avatar
K-G
Originally Posted by tony_2018
helicoil, timserts?
I tried to find them in the store but couldn’t find the proper size anywhere. I’m assuming I will have to order them
Old Mar 23, 2019 | 10:18 AM
tony_2018's Avatar
Fish Twig
ordering them is the only way. I had to order timeserts from amazon, looks like the kit came with everything plus extra timeserts in case another stupid header bolt thread came loose.
Old Mar 23, 2019 | 10:25 AM
K-G's Avatar
K-G
explains why nobody had them. Anyways thanks for the replies guys👍🏼👍🏼 Not sure what I’m going to do about this hole yet.
Could I maybe shove some jb weld like 3/4 way down the hole and just not tap as far ? And make one stubby bolt ?
Old Mar 23, 2019 | 11:03 AM
tony_2018's Avatar
Fish Twig
most parts stores don't carry everything, they can only hold so much.
Old Mar 23, 2019 | 04:14 PM
chrysler kid's Avatar
I mean autozone carries the tap and insert set for the size you need. Soo
Old Mar 23, 2019 | 04:47 PM
DaX's Avatar
DaX
Loved
Community Favorite
Time-Sert also makes a Big-Sert, so you can repair a REALLY jacked up hole and keep the same thread size, if needed.
Old Mar 23, 2019 | 08:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I vote TimeSert as well.
Old Mar 24, 2019 | 02:27 AM
K-G's Avatar
K-G
autozone does not carry Helicoil m12 1.25. I’ve looked everywhere in person.
Advanced, autozone and pep boys.
Old Mar 24, 2019 | 02:28 AM
K-G's Avatar
K-G
Looks like I’ll be buying a timesert kit I suppose
Old Mar 24, 2019 | 03:52 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Take the time to take off the case. It's really not difficult and you can ensure you get no chips in your gears and end up with a broken transmission. There is no other right way to do it.
There is enough meat on the holes that you can drill and re-tap the new/bigger threads, or just use a timesert/helicoil. I'd prefer drilling/tapping over an insert, but if one does not know what they are doing, they may muck it up more. Worst case, weld the holes shut and re-drill them, it's only metal
Old Mar 24, 2019 | 05:21 AM
mk378's Avatar
+1 on take the case apart, since there is a hole that goes through, there's likely already debris inside that needs to be cleaned out. And be careful not to go too deep on the other holes. The hole that goes through you'd want to put sealant on the bolt to keep water from getting in or oil from leaking out.
Old Mar 24, 2019 | 09:37 AM
K-G's Avatar
K-G
Update: ran the tap thru the block and just made some new threads deeper down and used some longer bolts. They torque good.
I will b locktiting the bolts with red locktite just for some insurance.
Also will be buying a torque mount.
Old Mar 24, 2019 | 12:35 PM
DaX's Avatar
DaX
Loved
Community Favorite
EG Civic with D-series? If so, shoot me a PM, I just pulled mine off since I went with upgraded mounts. I even went ahead and filled the mount with window weld. I'd let it go for cheap.
Old Mar 24, 2019 | 01:03 PM
Ok so now I remember. The kit for m10×1.25 has a tap that is m12x1.25. I went bigger on my dsm
Not shown, I had to pull the trans again anyways because the pivot ball in the brand new trans needed a shim
Old Mar 24, 2019 | 01:19 PM
K-G's Avatar
K-G
B series. Thanks anyways though!
Old Mar 24, 2019 | 01:20 PM
K-G's Avatar
K-G
ouch.looks like it came out good tho
Old Mar 24, 2019 | 09:51 PM
tony_2018's Avatar
Fish Twig
Right, it always goes up one size
Old Mar 28, 2019 | 06:50 AM
K-G's Avatar
K-G
Update: motor is in car running perfectly fine. Mount is not going anywhere. Thanks for the replies guys
Old Mar 28, 2019 | 06:52 AM
deschlong's Avatar
Loved
Community Favorite
Grand!
95sloweg
Sep 10, 2010 09:31 AM
EfSedanLove
20
Jan 25, 2010 07:51 PM
Baryndor
Sep 23, 2009 08:47 AM
grog
Apr 25, 2008 06:44 AM
draperj09
Feb 4, 2008 06:39 AM
