'97 Civic Tail Lights turn off when Braking
Old Mar 19, 2019 | 01:57 PM
Sammycookies's Avatar
Icon5 '97 Civic Tail Lights turn off when Braking
Greetings,
I just bought a 1997 Civic and the only thing keeping it from passing safety inspection is that the turn signals stop working whenever the brakes are applied. It stops making the turn signal noise as well. As soon as the brake is released the turn signal resumes as normal. Any ideas?? I looked at all harnesses and connections in the trunk and they look good.
Old Mar 19, 2019 | 04:19 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: '97 Civic Tail Lights turn off when Braking
BAD BULBS
Old Mar 19, 2019 | 05:07 PM
mk378's Avatar
Bad ground on the bulbs (outer shell part of the socket corroded) or a broken ground wire in the trunk.
Old Mar 20, 2019 | 01:19 PM
Figured it out!
It was a bad ground connection above the trunk under the back window. Screw was loose. Tightened it down and everything works great now! Got it inspected today and hopefully registered tomorrow!
BIGef
Jan 17, 2013 03:08 PM
JDM-JAMES
Apr 9, 2012 03:54 PM
corps
Feb 1, 2011 12:13 PM
1989Prelude
Oct 12, 2005 05:29 PM
DV98CVC
Aug 22, 2002 06:23 PM
