Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
08 Accord Power Door Always Locked
Old Mar 14, 2019 | 03:25 PM
Faradymd's Avatar
Default 08 Accord Power Door Always Locked
Hello, I have following problem with 2008 Honda Accord LX. First to turn the key right. No action. Turned back and felt restriction. Forced back and removed the key. Used remote of another key to open it. Tried to lubricate it with grease in the key hole. It was the same as before. Then used remote to open it, It switched to open and then switched back to close immediately for all four doors. Pulled the door open in between of open and close. Tried to disabled the auto lock setting. It didn't work. It clicked twice after 5 seconds. The door still locked. The lock above door handle inside can't be moved. Is there anyone know where the problem is? Actuator? Relay? Ground? and how to fix it? Thank you very much in advance.
Old Mar 14, 2019 | 03:52 PM
Faradymd's Avatar
Default Re: 08 Accord Power Door Always Locked
It is probably a problem of electronic control since the actuator receives the signal of locking the door all the time.
Old Mar 24, 2019 | 03:26 PM
Faradymd's Avatar
Thank you for your information. I replaced the actuator today. It's the same as before. It may be the lock cylinder out of order.
chiboy162
Nov 15, 2016 07:37 AM
DFH
Nov 23, 2014 05:32 PM
snapplez
Jul 27, 2013 04:23 PM
honda_accord_215
Nov 18, 2005 10:15 PM
