08 Accord Power Door Always Locked - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Old 03-14-2019, 03:25 PM
Default 08 Accord Power Door Always Locked
Hello, I have following problem with 2008 Honda Accord LX. First to turn the key right. No action. Turned back and felt restriction. Forced back and removed the key. Used remote of another key to open it. Tried to lubricate it with grease in the key hole. It was the same as before. Then used remote to open it, It switched to open and then switched back to close immediately for all four doors. Pulled the door open in between of open and close. Tried to disabled the auto lock setting. It didn't work. It clicked twice after 5 seconds. The door still locked. The lock above door handle inside can't be moved. Is there anyone know where the problem is? Actuator? Relay? Ground? and how to fix it? Thank you very much in advance.
Faradymd is offline
Old 03-14-2019, 03:52 PM
Default Re: 08 Accord Power Door Always Locked
It is probably a problem of electronic control since the actuator receives the signal of locking the door all the time.
Faradymd is offline
Old 03-17-2019, 11:54 PM
My friend also facing this problem in his towing truck which he uses for Queens Towing Service in New York, will let you know tomorrow about the solution.
marthawilliam is offline
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
