Need help identifying plug
Old Mar 14, 2019 | 03:07 PM
K-G's Avatar
K-G
Default Need help identifying plug
What is this plug for ? Trying to clean up previous owners mess. I have no ac. And also I am running HIDS. Everything works perfectly fine. I also have a second pink connecter that nothings connected to with a ground wire coming from it. Any info would be appreciated thank you.
Old Mar 14, 2019 | 08:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Need help identifying plug
It is not stock on a Honda. I dare not speculate as to what it is and why it is there. Maybe a pic from further out to see what is around... it may help.
Old Mar 15, 2019 | 02:47 AM
K-G's Avatar
K-G
appreciate all the help with the info you’ve given me the past couple months.
however this is what the bay looks like.
Old Mar 15, 2019 | 02:50 AM
K-G's Avatar
K-G
On the left side of the headlight. You can see the two plugs. Blue & pink. (Not the capped ones)
Old Mar 15, 2019 | 02:53 AM
K-G's Avatar
K-G
I relocated a lot of the wires. I didn’t cut any of them. Just moved them out of the way. It was a huge mess.
Now the only things I have there are hids plugs.
Im just so confused on what the pink plug to blue is.
I also have a second pink plug on the right side headlight that’s not connected to anything with a ground wire coming out.
Old Mar 15, 2019 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Does any of the wiring in question connect to the HID's (headlight wiring) ??? Some HI/Low beam HID's have a crossover sub-harness that typically only connects on one side.
Old Mar 16, 2019 | 05:43 AM
K-G's Avatar
K-G
I believe if I do follow them they will meet to the HID harness.
Actually you just sparked something. if I remember correctly last summer I had a issue with my lights & blinkers not working. But everything worked with the hazards though. I believe the plug that it may be for my lights.
will double check when I go to put my manual rack and give more info
evilclown312
Mar 29, 2011 07:37 PM
typeeg
Jun 22, 2004 03:41 AM
b18c-93
Sep 29, 2003 10:58 AM
