Need help identifying plug
https://cimg2.ibsrv.net/gimg/honda-t...5a74cc539.jpeg What is this plug for ? Trying to clean up previous owners mess. I have no ac. And also I am running HIDS. Everything works perfectly fine. I also have a second pink connecter that nothings connected to with a ground wire coming from it. Any info would be appreciated thank you. |
Re: Need help identifying plug
It is not stock on a Honda. I dare not speculate as to what it is and why it is there. Maybe a pic from further out to see what is around... it may help.
Originally Posted by JRCivic1
(Post 51887996)
however this is what the bay looks like. |
On the left side of the headlight. You can see the two plugs. Blue & pink. (Not the capped ones) |
https://cimg9.ibsrv.net/gimg/honda-t...42c57d5f6.jpeg I relocated a lot of the wires. I didn’t cut any of them. Just moved them out of the way. It was a huge mess. Now the only things I have there are hids plugs. Im just so confused on what the pink plug to blue is. I also have a second pink plug on the right side headlight that’s not connected to anything with a ground wire coming out. |
Does any of the wiring in question connect to the HID's (headlight wiring) ??? Some HI/Low beam HID's have a crossover sub-harness that typically only connects on one side.
(Post 51889159)
Actually you just sparked something. if I remember correctly last summer I had a issue with my lights & blinkers not working. But everything worked with the hazards though. I believe the plug that it may be for my lights. will double check when I go to put my manual rack and give more info |
