HELP! Will idle. WONT drive.
I have a 93 civic. Out of NOWHERE On my way home from work it started sputtering and back firing whenever i put my foot on the gas. Came home pulled tge spark plugs and they had oil on them so I assumed that was the problem. Put a new valve cover gasket on it with the spark plug tube seals, new spark plugs and new wires just to be sure. It was hard to start after that but then got it started. Drove it and Welp it kept doing it .Backfired so much it blew the baffle out of my exhaust The next day it WOULD NOT start no matter what. It would crank and want to catch SOMETIMES but still not start. Put a meter on the dizzy and it had little spark. $150 later we got a new dizzy and it starts fine. Heres the problem, it idle fine but as soon as you put it in gear it wontill wont to die. You put your foot on the gas and it spits and sputters and then dies. Help! Any ideas before I just sell it.
A modern engine backfiring almost always means that the timing is wrong. This sudden decrease in performance and inability to rev up is very often because the timing belt has skipped, which does occur suddenly.
popthatclutch13
19
Aug 18, 2018 04:51 AM
hondaless
Aug 4, 2004 01:03 PM
