Question? Crank sensor wiring for swap
Old Mar 11, 2019 | 02:29 PM
Bjm1118's Avatar
Default Question? Crank sensor wiring for swap
Heu guys, I’m sure there is a post on this. But my question is this, I am doing a obd2 GSR swap into a 98 civic EX. Ran into a little snag. The crank sensor by the crank pulley of course does not plug into or match the ex harness. Due to the plugs not matching and the EX is a 3 wire and the engine harness is a 2 wire. I’m running a obd2 p72 ECU. What do I need to do. Thanks..
Old Mar 11, 2019 | 09:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Question?
Un-pin the three wires from the three wire engine harness CKF plug and un-pin the two wire plug on the GSR engine harness. Tape back the brown wire on the civic engine harness and insert the two remaining wires into the grey plug removed from the GSR engine harness. Plug it into the sensor. Done.
Old Mar 12, 2019 | 04:58 AM
Bjm1118's Avatar
Thank you
mikej33
Jun 5, 2015 09:44 AM
KidRuthless
Mar 19, 2014 01:07 AM
damianw22
Nov 12, 2013 12:57 AM
98ej8coupe
Jan 28, 2008 09:05 AM
backagainracer
Dec 24, 2006 03:59 PM
