92vx b16a3 swap questions
Old Mar 10, 2019 | 05:36 PM
92sieghb's Avatar
Default 92vx b16a3 swap questions
I have inherited a 92 vx civic with a 95 b16a3 swap that I installed it doesn’t hit a lick when trying to start seems to have a extra plug on the passenger side shock tower not connected to anything what it is
Old Mar 10, 2019 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 92vx b16a3 swap questions
Do you have distributor related codes ??? It looks like it has the CKP and CYP sensor wires in that plug... is the plug that you have pictured part of the chassis harness or the engine harness and is it found over near the right shock tower ???
Old Mar 11, 2019 | 06:05 AM
92sieghb's Avatar
that plug is part of the chassis harness the distributor is plugged in and it just turns over no eco codes I can’t find out what that plug is for and what is involved with doing a b series swap into a 92 vx hatch
Old Mar 11, 2019 | 07:32 AM
AllMtrRex's Avatar
Looks like O2 sensor plug on the harness side
https://honda-tech.com/forums/hybrid...ctions-644434/
Old Mar 11, 2019 | 09:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Are you using the VX engine harness or do you have a different engine harness ???
Old Mar 11, 2019 | 11:56 PM
bigjon1378's Avatar
it is possible that that plug is for the lean burn stuff and egr, but i belive that stuff is on the driver side so im not sre if that helps
Old Mar 13, 2019 | 02:56 PM
Relic1's Avatar
that is a plug designation C129, it carries the wideband O2 wires.
that blue wire running from it is likely the crude solution to pull the correct wire out to run a narrowband.
If you are running anything other than the stock P07 ECU and wideband combo, you do not need it. (blue wire extension excluded of course)
one of my old writeups with detals
hybridnorth
13
Jun 21, 2018 07:29 AM
shadytreeworks
Apr 5, 2009 07:32 PM
bdubnyc
Feb 10, 2008 03:27 PM
transpar_nt
Dec 11, 2005 11:27 AM
