How to install 3 port oil catch can
Guys I'm a bit confused.i have a 3 port sealed oil catch can to put on my turbo b16 but I'm not sure how to route the hoses.
The can has 2 holes for in and 1 for out.how would I route the hose from my pcv and the port from my valve cover to it so that the fumes are recirculated into the engine?or do I leave one port out to atmosphere? Do I connect the vacuum that the pcv hose was connected to the can also or not?
Buy this one and thank me later its plug and play and super easy to install. That can you have is complete **** and most likely not baffled or has everything needed to replace the OEM PCV system.
ect-import-honda-b-series-vtec-oil-breather-can-kit-streetpush-lok-fittings/
https://www.youtube.com/watch?v=pKW16jU306k
Ok just watch the video and copy how they hooked up the vacuum hoses. Might have to cap the center or one of the ports unless its for a drain which I doubt.
^^^ I have a similar CC in my car. The petcock wasn't the greatest and started to leak so now it's draining downwards via 6AN braided line.
turbosivtec
Mar 21, 2012 02:43 PM
schpiel
Jul 9, 2007 08:57 PM
