How to install 3 port oil catch can
Guys I'm a bit confused.i have a 3 port sealed oil catch can to put on my turbo b16 but I'm not sure how to route the hoses. The can has 2 holes for in and 1 for out.how would I route the hose from my pcv and the port from my valve cover to it so that the fumes are recirculated into the engine?or do I leave one port out to atmosphere? Do I connect the vacuum that the pcv hose was connected to the can also or not? |
Re: How to install 3 port oil catch can
https://cimg9.ibsrv.net/gimg/honda-t...d1f0b4c911.png
This is the one I have |
Buy this one and thank me later its plug and play and super easy to install. That can you have is complete shit and most likely not baffled or has everything needed to replace the OEM PCV system.
ect-import-honda-b-series-vtec-oil-breather-can-kit-streetpush-lok-fittings/ |
Originally Posted by wunfstgsr
(Post 51883827)
ect-import-honda-b-series-vtec-oil-breather-can-kit-streetpush-lok-fittings/ https://www.youtube.com/watch?v=pKW16jU306k |
Originally Posted by thugsbryan
(Post 51883834)
thanks for the advice but i need sump that doesnt vent to atmosphere,this can i have is baffled,it has a filter inside too,i just want to know how to connect the 3 ports properly using the pcv hose and the port from the valve cover
^^^ I have a similar CC in my car. The petcock wasn't the greatest and started to leak so now it's draining downwards via 6AN braided line.
