tranny wont catch gears
Old Feb 26, 2019 | 01:50 AM
Ethan Garrard's Avatar
Icon4 tranny wont catch gears
so it started just the other day im at a light turning left im in d4 and i hit the gas and its like the car is in neutral i have to turn the car off and back on 4 or 5 times before it finally goes into gear then on my way home while im driving it does the same thing i have to pull over and turn the car off and back on 4 or 5 times before it catches gears i have not codes and no lights on
Old Feb 26, 2019 | 02:59 AM
TimiK's Avatar
10 Year Member
Default Re: tranny wont catch gears
auto or manual?
Old Feb 26, 2019 | 03:25 AM
Originally Posted by TimiK
auto or manual?
automatic type sh
Old Feb 26, 2019 | 03:53 AM
TimiK's Avatar
10 Year Member
5th gen auto transmissions are just... bad and waiting for failure
Old Feb 26, 2019 | 06:55 AM
motoxxxman's Avatar
check fluid level.
if it still acts up, get the trans hot, then drain all fluid, remove all solenoids and clean them, then reinstall and add fresh fluid to proper level again.
if it still acts up, buy a manual
Old Feb 26, 2019 | 08:09 AM
Thanks I will give that a try
do you think it could be the neutral safety switch
Old Feb 28, 2019 | 03:43 AM
Ok I changed the transmission fluid and now it won't shift out of I believe 2 gear
Old Feb 28, 2019 | 04:59 AM
TimiK's Avatar
10 Year Member
Manual swap
Old Feb 28, 2019 | 01:58 PM
WTRTransmission's Avatar
Transmission time😀
Just a matter of time before it completely leaves you stranded.
Old Feb 28, 2019 | 08:08 PM
TimiK's Avatar
10 Year Member
https://shop.synchrotech-transmissio...-P9801-426.htm
of course you need manual ecu there as well
Old Mar 1, 2019 | 06:40 AM
motoxxxman's Avatar
I'm not 100% sure on this, but I'm pretty sure you're supposed to check the fluid level with the engine NOT running. I know this is how you do it on older preludes. Is this how you checked fluid level?
brandonm718
Apr 21, 2017 06:09 AM
specialty
Honda CR-V & Element
Oct 16, 2012 05:37 AM
Linh.
Feb 13, 2008 04:07 PM
iNCREDiBLYSLOW
Aug 30, 2006 08:04 PM
96Civic_Coupe
Mar 31, 2006 05:50 AM
