Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 crv vibration at idle and takeoff
Old Feb 21, 2019 | 01:57 PM
CRV SE's Avatar
Default 2005 crv vibration at idle and takeoff
I own a 2005 CRV SE, bought it with just under 70,000 miles on it
At around 75,000 miles it started vibrating at idle, its 100% not an ignition issue, but I am having a hard time to pinpoint it.
Usually I would say motor mount, but most of the time I can get the vibration to go away using a floor jack, but have not been able to do that in this case.
I did replace all the motor mounts with AFTERMARKET mounts, which made the problem worse if anything, so I put all the oem mounts back in.
While they were out I did inspect them and the appeared to be good.
At about 90,000 miles I started noticing a hard vibration on initial takeoff from a dead stop.
The car does not vibrate after the initial takeoff, only then and at idle.
The oem mounts are about $500 for all 4, now I dont mind spending the money, but the last thing I want to do is spend that, and it not fix the problem.
In theory it should be the answer, but I'm not certain, and its a lot of money to gamble with if it doenst fix it.
Any thoughts?
Old Nov 16, 2022 | 11:21 AM
ribrickulous's Avatar
Default Re: 2005 crv vibration at idle and takeoff
OP - did you manage to find a fix to this? Girlfriend's '05 CR-V LX has a very similar issue.
Old Nov 17, 2022 | 02:37 PM
DREWdabuilder's Avatar
Community Builder
Check your axles. If they are the axles, stick to oem.
genetsang
Sep 30, 2023 05:15 PM
DaChoZn1
Jan 6, 2011 08:45 AM
6footmidget
11
Mar 10, 2009 07:20 PM
shraz
Honda Civic (2006 - 2015)
Jan 13, 2009 10:33 AM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
