rebuilding an s40 and orientation for shift forks
Old Feb 20, 2019 | 12:43 PM
Dustinninja's Avatar
Default rebuilding an s40 and orientation for shift forks
Hey all,
Recently this past month I’ve taken the project of rebuilding my transmission.
Some Background: I’m rebuilding the s40 that came out of a 1999 honda civic dx hatchback
The engine is d16y7 (non vtec) and 1.6L obd II
This is the first time I’ve rebuilt a transmission. I took my trans out when I first bought the car I thought the clutch or something was making a bunch of noise, shortly after I replaced the clutch the noise was less but was still there. It was the input shaft bearing. So, I took out the trans and brought it inside. I started taking it apart, removed the interlock guide bolt and I separated the case half’s, pulled out the main shaft, countershaft, and fork assemblies. Then I replaced the countershaft bearing, main shaft bearing, diff bearings and oil seals. I now have the main shaft, counter shaft, fork assemblies and diff back in and I don’t know how the orientation of the “change piece” goes. In my helms it says “set the change piece” read a little bit further and it says “NOTE: Align the finger of the interlock with the groove in the shift fork shaft.”
What does the alignment look like? They show no pictures.
Also, when do I put the interlock guide bolt back in. Everywhere I read tells me first bolt out last bolt in. But does everything need to be in neutral first? Should It be in second or third gear so the trans closes then put it in? Another thing is everyone says just put it in when its an “empty” hole or has nothing on the left or right of it that would obstruct the bolt.
Lastly, how would I bench shift my trans? I have a screw driver through the nub that the linkage bolts onto but it’s so hard to pull backwards and push forwards, surely it’s gotta be something with the shift forks orientation. Also a side note is that the main shaft does spin freely so there is no binding.
Thanks all to who respond I’m just trying to figure this out
If at all possible if someone have a picture for orientation so I can compare to how my trans looks and go from there.
Old Feb 21, 2019 | 04:09 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: rebuilding an s40 and orientation for shift forks
I know this is for B-series, but it's similar - 14th picture down in this post: https://honda-tech.com/forums/transm.../#post36579942
When all the gears are disengaged (neutral), the grooves at the base of each of the three shift fork shafts are all aligned, and the interlock fits inside them. Kind of hard to explain.
Get the counter shaft, main shaft, and shift fork assembly all back in the clutch housing, and disengage all gears (put it in neutral). With it in neutral, this is when I like to install the interlock bolt, before the case is on.
Use a screwdriver or a drift pin in the shift rod's "bitch pin" hole. It's more difficult than shifting the transmission in the car because you don't have the same amount of leverage, but it should shift into all gears on the bench.
Old Feb 21, 2019 | 04:36 PM
mk378's Avatar
Yes the purpose of the interlock is to make sure that only one shift fork can be out of neutral at a time, so you need to move them all to neutral first. The slots should line up. Then lift the shafts, shift forks, everything out of the case slightly so you can rotate and slide the shift dog and interlock cage into position in the slots in the shifter forks. Put in the bolt that holds the shift dog to the shifter shaft. Finally install the pin bolt that comes in from the flywheel side to limit the motion of the interlock cage.
It won't operate smoothly on the bench with the case apart, the shafts flop around too much.
Old Feb 21, 2019 | 06:38 PM
I got the selector all lined up And i figured out the bench shifting
Old Feb 21, 2019 | 06:48 PM
This is the interlock bolt hole
is this the right “cage” you were talking about nothing is obstructing the bolt from left or right
everything is in neutral
it should just fit right in but it doesn’t thread all the way in by hand
Is this right? I’m not going to force the bolt in i don’t want to bend it or break it
Interlock bolt hole
Old Feb 21, 2019 | 07:03 PM
Before i close everything up
how do i shift into reverse?
should i put Vaseline on the syncros?
Old Feb 21, 2019 | 09:45 PM
I figured out that when you bench shift the transmission the screw driver is just like a shifter and needs to be twisted left and right to get into gears
haha oops
so i shifted through all gears no binding
but reverse is so hard to get into no matter how much force i put on it i can’t shift into it. Is this normal?
would Vaseline help shift it better?
Dustinninja
Transmission & Drivetrain
Feb 21, 2019 09:46 PM
jdmfreak1992
Honda Civic (2001 - 2005)
Jul 26, 2011 04:52 PM
Uncle Ben's
Jun 2, 2010 09:10 PM
andrewd_89
Feb 10, 2010 04:21 PM
Pbanto
Apr 8, 2009 05:07 AM
