Assistance needed: Ignition Timing Question
Old Feb 19, 2019 | 11:51 AM
MastaFlyMason's Avatar
Default Assistance needed: Ignition Timing Question
I was setting the timing on my b16 and had a small issue. Car is warmed up, running at 800RPM with the service pin jumpered and the timing light hooked to the #1 plug wire. When I set it the distributor is pushed all the way back toward the firewall and that looks perfect. Seems weird that I wouldn't have any more adjustment, but when it is fully back it looks spot on. I checked my base timing and with my crank pulley lined up with the timing mark the cam gears look spot on, both facing up with the alignment notches directly across from one another. I tried a new dizzy thinking maybe my CPS was going bad but it did the same thing. Is there an issue here or is this normal?
Old Feb 19, 2019 | 01:15 PM
Default re: Assistance needed: Ignition Timing Question
Figured it out. Got a code for for crank sensor, bad wiring. Is there a better obd0 to obd1 than Rywire? Kind of pricey
Old Feb 19, 2019 | 01:27 PM
2x0's Avatar
2x0
10 Year Member
Speed Factory or ebay...
Old Feb 19, 2019 | 01:48 PM
Thanks ended up just going Rywire I heard only good things
Old Feb 19, 2019 | 08:45 PM
motoxxxman's Avatar
Boomslang is the ONLY company I trust for conversion harnesses. And they offer warranties on all their products. Not many others can say that
Old Feb 19, 2019 | 08:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Boomslang Fabrication is my choice as well. Great product.
Old Feb 20, 2019 | 05:23 AM
2x0's Avatar
2x0
10 Year Member
Damn, I completely forgot about Boomslang, but you guys are right. I bought my OBD2-OBD1 harness from them maybe 15 years ago and it worked great. Surprised they are still making this stuff after all these years.
Old Feb 22, 2019 | 06:58 AM
TheShodan's Avatar
Moderator
Been using them since '04. Great stuff. Very quality
Old Feb 22, 2019 | 11:32 AM
AllMtrRex's Avatar
Default Re: Assistance needed: Ignition Timing Question
+1 Boomslang. Purchase one of these and never go anywhere else. Jason Koehler (JKOBD) also made adapter harnesses for honda/acura. Exceptional Quality. I don't think he makes these anymore.
Derrick_12341
Aug 10, 2018 07:03 AM
ls-v
10
May 1, 2007 07:43 PM
Jorsher
Oct 24, 2004 04:51 AM
VisualEcstasy
Apr 15, 2003 09:00 AM
Norcalstoppy
Nov 12, 2002 11:32 AM
