1991 civic d15b2 timing
Old Feb 17, 2019 | 02:11 PM
insane302cancan's Avatar
Default 1991 civic d15b2 timing
Hey guys, having some issues. I inhereted a 91 civic dx hatch back. Went to go change the head gasket since the graphite one was starting to go (pressurizing the cooling system) So i ended sending off the head to the machine shop to have it resurfaced, they found it need new valve guides and a valve job also. so we went ahead have all that done. I ended up putting the head back on, with the newer style MLS headgasket. New timing belt set, and a new long tube header (it was stupid cheap) Well, got it all together and now it idles like crap. Thought it was the timing belt, I ended up retarting and advancing the belt a tooth, made it worse. Checked for vacuum leaks, nothing. Not entirely sure whats going on. Nothings changed other than the headgasket, and long tube header. it seems to run alright going down the road, just cant figure out why it idles rough.
I did not adjust valves, maybe that might be the issue? im open to any suggestions. Timing belt was put on with the two slashes flush with the head surface and the crank aligned with TDC mark on block.
Old Feb 19, 2019 | 06:39 PM
arries289's Avatar
Default Re: 1991 civic d15b2 timing
If you are 100% sure the timing marks lined up, and the only issue is idle, you need to look for vacuum leaks. Before you do that, you absolutely need to adjust the valves properly thou.... Use some carb cleaner to see if you can find a leak around the intake. Check for loose clamps or missing vacuum lines.
chipper
10
Jul 4, 2013 10:59 AM
armintheman
Oct 4, 2010 01:05 AM
Tb0y
15
Nov 14, 2007 06:03 PM
97em1
Jun 28, 2007 11:05 AM
88hatchef
Nov 21, 2005 04:46 AM
