Key lock cylinder help!!!!
Old Feb 16, 2019 | 08:46 PM
Timothy Yhtomit's Avatar
Default Key lock cylinder help!!!!
Recently bought a eg that was stolen before. The key isn’t Present so the dude that I bought it from gotten a different lock cylinder and was using a different key. The doors aren’t lockable because it’s a different key. I was wondering if I could use ek doors, trunk, and key lock cylinder on eg? And i was also wondering if Honda still makes lock cylinders I could buy instead of having to find lock cylinders at the junk without keys along with it. Thank you
Old Feb 17, 2019 | 06:27 AM
mk378's Avatar
Default Re: Key lock cylinder help!!!!
Have a locksmith make a key that fits your doors and re-key the ignition to that same key.
Old Feb 18, 2019 | 10:07 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Go to the dealer and have a key made for your car. There's a code for your VIN and they cut it to that. Now you have a door key! From there, you check the DIY about "Fixing a lock that works with any key" and you will see the little bits you need to match your ignition key to the door key. Little tabs inside the lock cylinder that "read" your key and allow the cylinder to turn. Very very easy once you figure out what you're looking at. Removing the ignition cylinder also quite easy. Check the shop manual (this can be downloaded with a quick google search.)
FOSSdude
Feb 13, 2020 09:31 AM
2001GSRSC
Oct 3, 2017 07:49 AM
kevinhughes13
Jul 28, 2013 11:18 PM
hyperblu
Sep 7, 2011 05:59 AM
NathanielH
Jul 17, 2007 07:38 AM
